Just recieved my FP3, I need help picking a map to start with...
Kevinmach1
I had V&H powerduals installed recently to go along with 4" Rinehart slip ons, and a SE HD air cleaner. This is on my 2014 streetglide "firefighter".
I ordered a FP3 and I don't see that combo anywhere in the list of maps. Any recommendations?? I hope to play with the auto tune feature once I become more experienced with this tuner...
Thanks..Kevin
When I talked to V&H they said just use the Generic Slip-ons, Hi flow A/C is assumed according to them.........they then said to engage the auto-tune process and get it completely dialed-in.
Good luck!!
I have the same exhaust set up as you on my 15 SGS, with an Arlen Ness Big Sucker. When I got my FP3 and talked to V&H, the maps below are what they suggested. Bike ran great! I am running Auto-Tune now just to see if I can bleed any more performance from her.
15T1031978- Turn Down Slip-Ons w/Power Duals/Standard Baffle, Throttle Position: Moderate
15T1031963- Twin Slash Round Slip-Ons w/Power Duals/Standard Baffle, Throttle Position: Moderate
Give their support line a call. They will tell you the closest map to your set up and then you go from there.
