King Tour Pak
Aviator5456
293
I recently bought an after-market King Tour Pak that came with a liner. It all seems descent quality, though not near as good as OEM. It didn't come with the baseplate (ground plate) so I bought a used one from another member. After I installed the tour pak with baseplate, the liner no longer fits as it's molded to fit without the baseplate. My question is do the OEM liners fit the same or are they molded to account for the baseplate? My options with this is to install the liner, then the baseplate, though I would have to make holes in the liner for the mounting bolts. I don't like that idea because the wiring harness fits under the baseplate and I would have to install something over the baseplate to keep it from damaging whatever I put in the tour pak. Thanks for any inputs.
Good morning fly boy. I used an older tour pak on my 2014 and all I had to do was drill out the baseplate to fit the newer mounting plate if that makes sense. I'm not understanding why you needed to replace the inner base plate ?
I just got a plastic cutting board from Walmart and cut/drilled it to use as the inner plate. Easy peasy.
If you're referring to the OEM rubber floor liner for the trunk, they come cut to an exact fit without any holes.
jdtech17
