I have a 2012 SG with a 107 build which was set up with 10.5 to 1 compression ratio. When checking for cranking compression I only get 140 lbs on both cylinders. I have followed the SM instructions and disconnected the CR and have the throttle body wide open. The bike DYnos out at 112 hp and 118 lb torque and runs strong. Big Boyz compression calculators said it should make around 175 lbs with 585 cam at 5600 ft of elevation. What am I missing here. Tried both cold and hot with similar results.
Mike T
Mike T
