Lower faring
Noted, thank you tomA.
Take a look at the way other people have them mounted before you try as they will scratch the chrome. If you have a tire lock or stand where you can lock the bike in level and straight up and use a large square a tape to make sure they are both in the same place. If they are off just a little bit you will notice while your riding and it will drive you crazy. Not a hard thing to do but if you get it wrong it will leave tracks you can't hide. Once you get them on you will use them a lot as the only time I put my feet on the floor boards is when I start off or shift maybe also dodging a cage or 2.
Another thing is to look at are all the different kinds of pegs out there. If your vertically challenged they make ones to work for you with a lot of pull back or if your tall mount them in front of the bars. Biggest thing is mount them so your knees are bent not at full flex because this will not be good. I have mine set up so my knees are bent and I can put my feet on top of them when I get really relaxed and stretched out.
Hi, I'm from Singapore and riding a 2013 SG Denim Black...bought my lowers from eBay via mutazu...not too bad though but can't compare with original..nevertheless it cost about 1/3 of original.
Thanks Mojo for the warmth welcome...hope to learn something from you guys...The Original USA...yeah!!!
Just dig into previous posts and you'll see all kinds of stuff and get some tips and ideas too!
Gary L Barrett
