well my audio problems continue. I posted a week or so ago saying that i had a loose connection to the amp that was causing the right speaker to work intermittently. I replaced the input and output harnesses to the amp (the output is the problem as far as i can tell, but the input was loose too) which helped but did not completely solve the problem. NOW, i have also realized that my right speaker is blown. the woofer cone produces a harsh pop now instead of the gentle thump of the double bass which I was attempting to enjoy.
I don't know what I'll do now. I don't feel comfortable spending $1k on a j&m kit (get rid of the troublesome amp and fix blow speaker, with a full upgrade) but I also am very leery to buy another Rockford amp that has the same connection type, knowing it could happen again. On the plus side, bike week is 34 days away and that's a good opportunity to check out some systems and prices, including to see what Paul Yaffe's Bagger Nation is using/offering nowadays.
I have never had so many audio problems. Before I got the amp, I had the Polk speakers only ran to the stock speaker harnesses but one of them too developed a loose connection. The common denominator is these pin and socket type connectors. needless to say I much prefer spade terminals if it can't be soldered.
for reference, my current setup is as follows
Cycle sounds line leveler
Rockford Fosgate PBR300x2
Polk MM651 speakers.
fairing only. two speakers total.
