motorcycle jack or wheel chock
I bought a JS a couple of months ago. You have to use it to believe it, awesome jack. As mentioned earlier, it's an expensive motorcyle, you need to be careful with it!
Spazz, I just picked up the HF chock. Have you done anything to the rotating portion to keep it from contacting the back side of the front fender?
I actually bought the HF wheel chock for my garage floor just for those occasions... $49 . Now... if you don't mount it to the floor you will NEVER drive up into it. that is the only drawback to the HF chock...
If I don't mount it... I just jack up the sled and place the wheel chock in place and set it into the chock and remove the jack. 3/8" Flush mount anchors work great and no trip hazards when you remove the chock.
It's cheap enuf... just trim it down if you need to
El Guero Jay
