Mounting Amp in fairing
Mgrasso211
4
Does anyone have a good solution to mount an amp in the fairing on top of the head unit? I was going to just velcro it but I thought I would maybe want a more stable solution.
THank you
Industrial Velcro is what we use most of the time.
There are some amp mounting tray/brackets available, JM makes a good one and Rockford Fosgate makes a good one also. I am sure there are others, but I have not used them
What he said. Use an amp plate
I bought a mount from Bagger Nation and worked very well. I was told velcro tape will not hold due to the amount of heat that comes out of these amps. With the mount it doesn't move at all and the way the mount is setup it has room for air flow. Check into it.
Link
You will be fine with the Velcro, mines been in place for over 2 years without a problem.
