Need bars on a '15 Ultra Limited.
buckshot85
844
Yup, I know this is the SG forum.
What's the latest word on how tall can I go with bars before having to change clutch and brake hose? Not concerned about wiring.
Looking to use Wild One Chubby 10s or maybe 12.5s.
The setup is the same on the batwings.... you can go 12's with just namz wiring extensions. No need for Hyd lines. I just did a 15 TriGlide.... no issues. You will have to free up a little slack on the lines on the right side of the neck at the triples, but that's it. cut the zip ties at the triples under the faring as well... this will free up slack.
Also... the banjo bolts for the master cylinders need to be loosened just unuf to orient them correctly, but not to much to lose fluid if you catch my drift.(it's metric )
FastJonnie64
