Need some quick help
rjjaxx
25
Don't have my manual yet:mad::mad::mad::mad:
Can someone give me rear shock torque value for a 2014 street glide???? smack dab in the middle of an upgrade and need this please??? thanks
I didn't use a torque wrench on mine, just used red lock tight and tighten them up. Just make sure after you tighten them up you and rotate the shocks.
Thankk you
Thankk you
Was kinda in a pinch on the install .......called dealer...... usually I am on top of stuff like this............thanks again ................Legends install done and works good .......not sure on how soft of ride it is..........judge is still out on that
That's what makes this Forum so nice, the help everyone is eager to provide each other. Lots of great info here!
For sure!!.... and actually good quality advice.. for example when I called the Harley shops I go three different answers???? Kinda sad I called local Harley dealer 1 and he came back with 40inch pounds. I told them that can't be right it must be foot lbs. he kinda of became an *&^. called dealer 2 to make sure and then I got 55lbs. So now you can imagine I am a little weary.... so I called dealer 3 and got 40 foot lbs. matching the blog so I believe them.
If you have manual would you have torque specs on fork pinch bolts, axle pinch bolt, axle nut. I would appreciate it if you did. I have my 09 manual and the set up is totally different. thanks.
Any updates on the legends ? Good bad ??
Sent from my SM-N920P using Tapatalk
chops92
