New Extreme Duty 98" 107" & 110" Drop In Fuel Moto Cylinders
fuelmoto
146
Fuel Moto Extreme Duty cylinders are designed for maximum durability and top level performance for Twin Cam engines. They are available with either a heavy duty centrifugally cast Ductile iron sleeve or hi-tensile strength steel liner (drop on kits). Cylinder & piston kits are CNC bored and honed to exact specifications and come ready to install. 100% made in the USA.
http://www.fuelmotousa.com/p-28613-extreme-duty-cylinders.html
All complete Fuel Moto 107" & Fuel Moto 98" kits are available with our Extreme Duty ductile cylinders for an additional $299 with NO core charge.
$899.00 FM107-0611 107" Fuel Moto Extreme ductile iron liner Cylinder/Piston kit fits 2007-2017 H-D Twin cam 96" & 103" engines (air & twin cooled). Available 10.25-11.0 comp (custom pistons available)No case boring required.
$899.00 FM98-0611 98" Fuel Moto Extreme ductile iron liner Cylinder/Piston kit fits 1999-2006 H-D Twin cam 88" engines. No case boring required
$999.00 FM110-0612 110" Drop in Fuel Moto Extreme hi-tensile steel cylinder/piston kit fits 2007-2017 H-D Twin Cam 96" & 103" engines (air & twin cooled) No case boring required. Available 10.5-11.0 comp (custom pistons available) Complete custom 110" engine kits are also available with piston/cylinder, cams, pushrods, lifters, gaskets, etc starting at $1699.00
Fuel Moto 110 "drop in" and 107 Extreme Duty piston/cylinder kits are now available with pistons for SE 110 & MVA heads in 10.5-11.25 compression for 07-later H-D Twin Cam models. These kits start at $899.00 including gaskets, just add your heads & cams of choice. Check them out at https://www.fuelmotousa.com/p-28613
Eric375
