New firmware upgrade for BoomBox dated 2/1/2016
flhrci
118
Appears to finally fix the bug that doesn't always keep the last selected media after ignition cutoff. And some others.
Date Released: 02/01/2016
Version 1.19.2
Change Log:
New Features
- High Contrast Day Colors
Issues Fixed:
Radio Fixes
- Radio off state remains after ignition cycle.
- Splash screen takes too long to disappear
- Blank menu buttons in high contrast mode
- CB channel and other text difficult to read in high contrast mode
- Road Glide Picon cut off
- Auto-reply nonfunctional after enabling in menu
- Auto dimming day/night transitions faster
Audio Fixes
- Audio quality "pumping" and "surging" improved.
Media Fixes
- Last media source remains after ignition cycle
- Favorite hard key not persisting with USB media after ignition cycle
Navigation Fixes
- GPS Time Incorrect (Incorrect time zone adjustment)
David
Hope it won't cause a problem with my Hogtunes setup. I've been told these updates don't play nice with third party equipment.
It's spotty... some do and some don't..... no rhyme or reason why it affects some of us with flashed units for aftermarket systems
And this is another reason I removed my 6.5 radio and installed a aftermarket radio.
is it better to go to HD and have done or can i do it online with a thumb drive?
I have been trying to install the new version but always appear a message that the image file is not valid". Has anybody problems to install the 19.2 version on 4.3 Radio?
I downloaded the firmware from HD web.
Thanks in advance
Thanks in advance
There are no issues with the download, there should be instructions at the Harley site.
I unzipped the download to my desktop and copied the contents to a thumb drive then plugged it into the bike.
FROM HARLEY:
Download the latest software version from harley-davidson.com
a. Select "Download Software Update" for the appropriate system.
b. When prompted, save the compressed file to your computer desktop.
c. When the download is complete, copy the file within the zipped folder to the root directory (the first or top most directory in
a file system) of a USB flash drive that is 8 GB or larger.
d. Turn your vehicle's ignition switch to ACCESSORY. (Keyless ignition vehicles: press and hold the trip switch for more than
two seconds).
e. Turn on the audio system and connect the USB flash drive to the audio system's USB port.
f. The audio system will detect the new software available and ask if you want to update. Select “Yes”. The display will prompt
you to remove the USB drive when the update is complete.
I just downloaded and updated mine tonite!! Thanks for the heads up on the update as I would have never known!!
Just download 19.2 and updated the bike, was on 17.1.. Easy enough.. Will see what changes on the next ride.
Thanks !
Petestreet18
