New Halogen Passing Lamps Tests and Pics
hulkss
622
Note: My links below are green, a shopping bot adds the red ones.
I put the H-D Auxilliary Lamp Kit p/n 67800367 on my 2014 SGS (lamps and bulbs are not included).
I'm just as much interested in being seen during the day as seeing well at night. I noticed that the new LED lights (and white lights in general) don't show much during the day. Here is a photo of the Truck-Lite Phase 7 headlamp on during the day. At this angle it does not show hardly at all.
I read a couple articles about yellow lights helping visibility: Yellow Bulbs and Selective Yellow
I ordered a pair of Adjure Passing Lamps p/n T40314 from Amazon. They are made out of glass & metal and use H3 halogen bulbs. They have a metal black dot bulb shield inside which is needed to prevent glare to oncoming traffic. Adjure Lamps
flash and regular exposure
I bought three 55 watt H3 bulbs: Clear, Golden Yellow, and Extreme Yellow
I projected a single passing lamp onto my home theater projector screen and photographed the light with my Nikon SLR. I used manual settings so all three pictures (one with each bulb) were exposed the the same. I combined the photos into one image to compare them. Clear on top followed by golden and yellow on the bottom.
All three colors are also available for the stock 2014 headlamp which uses a 65 watt H9 high beam bulb and a 55 watt H11 low beam bulb. I believe all three colors are legal in the passing (fog) lamps. A yellow headlamp is not legal in most states. MTEC claims the golden lamp is "100% suitable for car inspection".
When looking into the lamps from the side the Extreme Yellow is very yellow. The Golden Yellow looks between white and yellow as you might expect.
I will try the Extreme Yellow bulbs in the passing lamps, the Golden Yellow in the low headlamp beam, and a clear bulb in the high headlamp beam for maximum distance vision. With the 2014 SGS all four bulbs can be on at the same time.
I'm going to have to spend a little time read this in reviewing it. I put the auxiliary light Kit on my street glide as well black of course. I bought all of the regular bulbs and I'm using the Arlen Ness ring of fire turn signals. I've been trying to decide if I want to actually spend big money for the day makers.
DF, I really like those AN Ring of Fire running/turning light, real attention getters!
How easy were they to install? Do you have them as taillights also?
FB
FB
Couldn't be easier. Just like changing a light bulb. the LED lights are already installed in the lens cups so you pop off the stock lense, pull the bulb, twist the pigtail in the light socket and snap on the cup. thats it. here is a pic of the rear too.
I finish the Daymaker headlight and Aux light install this evening. I was disappointed to realized just as they did on my old Road King, when I switch to High Beam, my aux/passing lights turn off. Does anyone know which wire I need to attach of the 4 that will keep the passing lights on at all times? There are 4 wires that connect. One blue turn signal wire, one violet turn signal wire, one black turn signal wire and one gray auxiliary lamp wire.
I know I need to run the gray aux wire to one of the other three, but which one?
Thanks.
Aux lights on with high beam is a software setting in the body control module. You need to ask your H-D dealer to change the setting.
Just for information a lot of states have 1 light high beam laws so it's illegal to run the running lights on high beam. May never get stopped but if you do be prepared for what's coming and then again get the right cop and nothing said. I would run with them all on also but I just thought I'd bring that up so we are all informed
I have 6 HIDs on when driving the truck with the high beams on. Have not been stopped yet.
When installing the Aux lights, do you get a console switch like on the Ultras to turn on and off Aux Lights? I'm wanting to do this install on my 14 FLHXS.
Yes, and you need a software setting changed to keep them on with the high beam headlight.
Thank you hulkss. I searched everywhere for an answer before I asked. Well except the dealer. I like to be prepared before I go there.
Hi there. Question for you. I have a 2014 SGS and ordered the same auxiliary light kit. Can I use halogen lamps? Harley site says you cannot; you need to use LED. I would think that halogen
is possible; maybe not plug and play but possible. The parts I ordered were the following: Part Number: 67800367 (kit) and Part Number: 68208-98A (Clear Lens with Halogen Bulb). If you have any advice for me please share. Also, what is your feelings on using amber lamps vs white for auxiliary lights? A friend of mine claims the amber really makes you stand out.
Thanks much!
Thanks much!
I run amber LEDs now. Anything incandescent must be at or below 35 watts each.
El Guero Jay
