So today I set out to install my new set of Oberon adjustable brake and clutch lever. Brake lever when on without a hitch.
So now the issues, first the clutch does not fit even remotely snug, it has allot of vertical play! This should not be the case so I re-installed my OEM's and they have vertical play but minimal.
The second issue is when I conducted a operation check, it would not start in gear unless the level was set on 4/5/6 (1-6 with 1 being the closest to the grip)! After inspection I noticed the safety switch that sticks out does not fully disengage with the setting of 1-3. Is this what others are finding with these?
