No Cage Audio kicking off with a Killer new system for Streetglide's
Nocage
26
No Cage Audio’s 2014+ Streetglide faring only Kit.
No Cage has put together a new amp and speaker kit for those of you interested in a dramatic upgrade in the sound system on your 2014 and newer Streetglide’s. This system is completely plug and play with no cutting of any Factory wires.
This system is designed around the New Hawg Wired NX652-80 6.5” 2 ohm Component speakers which have the tweeter bridge mounted and comes with 2 way passive crossovers. These new speakers sound amazing with some of the best bass available in a 6.5” speaker. We match these speakers with the Arc KS 125.2 BX Mini amp. This is one of the most dependable, cleanest amps ever designed for a motorcycle. The NX652-80 2 ohm speakers let you take advantage of all the power this amp puts out (125 Watts RMS x2 channels at 2 ohms).
We also make use of Arc’s HD Harness and 2014+ Wire Kit Retrofit. This makes install and hookup a snap with this plug and play wiring kit. No Line Levelers are required with this kit
We think this is $$$ for $$$ the best entry level Plug and Play 2014+ Streetglide system on the market.
Now for the down side, this system as configured is NOT expandable. The use of the 2 ohm speakers to get the most power from this amp will not let you add another set of 2 ohm or 4 ohm speakers.
To the guys looking to upgrade their faring only setup, this is not a big deal. For those of you that are wanting to add more speakers down the road, we have some different options.
Check out our pricing and options on our sponsors page
Karl
I have discovered a OEM to Hawg Wired connector issue when connecting to the new speakers to a 2017 RG today. The connector snap does not hold together as well as it should and could vibrate loose. Until this issue is resolved (new connector design)I will suspend sales of the system. For those of you who bought (1) I will give a full refund or upgrade to the Arc Audio MPAK 12 system at my cost. I think this issue will be resolved very quickly but until it is I do not feel comfortable making sales on it
I am sorry for any inconvenience this has caused
Karl
Karl
Karl,
Any updates/ revisions on No Cage Audio’s 2014+ Streetglide faring only Kit?
Thanks
Just pm him, he replies to all of mine. I just installed an amp from him last night. Good product and fast shipping.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Karl's (no cage) message above implies that he'll let the forum know when it's resolved, at least that's how I interpret it. Why not just call him directly rather than relying on the forum. He's been great every time I've dealt with him and replied to messages very promptly.
Hey guys,
Thank you your patience, Hawg Wired has solved the connector issue. They are also are working on a more cost effective solution to the same problem that the Line Leveler solves (bass boost in the 2014+ HD headunit) Very shortly Hawg Wired will be offering a complete Amp, Speakers and plug and play wiring harness package for the 2014+ bikes. I will be Beta testing this new package in the next few weeks
Karl
