ok all I need your help.
Pistol Pete
We just picked up a 2004 electraglide that has 31000 miles on it. The problem I am having is that on the highway it feels loose. Not sloppy just loose. If i move the bars from left to right it really wobble easily it the front end at 50 plus mph where as if i do it on my 14 SG it snaps back to straight instantly and tight. I can also feel it follow/grab a grove in the highway. Now this only happens when when initiated otherwise its smooth and straight. Tire pressures are spot on. Could it be that I am just used to my 14' SG? Has anyone else ever experienced this? Hope this makes sense It is the best I can describe it.
Thank you all
Pete
Since it's the older.. frame, you will definitely feel the wobble. The swingarm and motor/frame flex opposite and cause the wobble. This was corrected in 2009 and newer. I recommend looking into the Bagger Brace...
http://bitchinbaggers.com/products/bagger-brace/
There are other products on the market as well... Touring link...
Amazon sells these... FYI
Besides Spazz's good point, look at these just in case:
May also want to check the neck bearing adjustment.
Is the front tire cupped or over/under pressure?
Anything loose or not torque on the front end?
My 14 FLHXS will find every groove in the road and wobble a bit.
buckshot has a good point- My first inspection would be the neck bearings.
SLYMIDAWG
