Optima digital 400 battery charger
mbloom
Has anyone used this type of charger/maintainer on their bike? The Optima Digital 400 comes w/ both clamps and ring terminals to connect to battery. Obviously I don't want to remove seat, ECU to connect to battery! I can see in the manufactures picture of the charger that half way down the charging lead you can disconnect/separate the charging lead to change between clamps or ring terminals. The connection is just like the battery tender connector on my 2014 SGS. I'm wondering weather I could plug the charger directly into the battery tender connection to charge/maintain battery?? Thanks Mike
Yes, it plugs straight in. Just remove the left panel, extract the socket and route it through the gap at the base, connect and refit the panel. Done.
Thanks for the input Tbird, I got the optima in the mail today plugged into battery tender plug on bike all good! R/ mike
jdtech17
