Paul Yaffe Install w/ Heated grips
Dan-O
22
I'm installing 10" Yaffe Monkey Bars and I'm doing it while routing the heated grip wires through the left side. Anyone else try this? Getting aggravated and haven't even started on the TBW! Might have to call it a night and start again in the morning cause the whiskey is starting to catch up lol. Any info would be appreciated
I ran 6 pull strings and taped them to the bars before I started. This was after I had already made one attempt and could not get a snake through to pull the last few bundles. Heater wires were the last I pulled.
12" Twin Peaks. Loose a string and I would have had to start from scratch.
Good Luck... Also used a spray dry wax lube that seemed a lot easier to pull than grease.
I don't have heated grips but for pulling wires for throttle through I took off the wire protective wrap and used electrical tape an heat shrank tubes which made it thinner and way easier to pull.
FastJonnie64
