Pbr300x2 amp, loose connections
azglocker
315
OK this has been an on going problem with my Rockford punch amp. The Input and output connectors to the amp are coming loose causing either speaker loss or intermittent sound. I just spent an hour trying to shim the plugs but it hasn't made any progress.
What can I do to tighten up these connectors? If there's no good way to tighten it up, I'm really considering a new amp. I am even considering just pulling the amp while I figure out how to fix it. I'd previously had problems with a loose Rca connector and even had to replace the oem style right side male speaker connector (which feeds to my line leveler).
Here's a pic of the wire connectors. Any brilliant ideas or even a good amp (preferably under $300 for a 2 channel around 200w) to consider will be accepted. I'm ready to cut off every connector I can and solder them just to eliminate future problems!
https://images.sonicelectronix.com/images/2357286/main/pbr300x4.jpg
Thanks for reminding me. I have read about this problem doing research for components. I installed my PBR last night but still waiting for speaker adapters. I plan to spot bead the plug in place with high temp RTV and secure the harness well..
1st post:D
Well welcome joker and not a bad idea! I tossed the entire system and installed a 330w j&m setup which has a nearly identical plug. I hope to never reply saying the same thing happened but who knows.
24CVORider
