Power Duals Part# help
danoday
100
I have a chance to buy a new in the box V&H power duals, the PN number on the original box indicates PN#-V16759, this is different than what is shown on the VH website. Does any one know if this will fit a 14 SGS? Thanks
After doing a cross reference with one of our distributors, it indicates that while this particular part number is indeed for a set of V&H Power Duals however, they are only compatible on '09 touring models.
Hope this helps!!
Lindsey :0)
Hope this helps!!
Lindsey :0)
Not the answer I was hoping for, but thank you very much for your help Lindsey.:)
Hope this helps!!
Lindsey :0)
That's GREAT support Lindsey! Jumping is as a Vendor to answer a pretty important question for a member is TOP NOTCH! But... I would expect nothing less from you... you are ALWAYS there to help! THANX!
Well... that just means you can buy the correct one from Lindsey!! LOL!!!
Spazz, no doubt about the above and beyond service by Lindsey not only for me but I have seen it for others as well on the forum. I have not purchased anything from Iron Aces and I have been kicking the can down the road on these headers for a long time, when I make my mind up I will definitely contact Lindsey first. Thanks again Lindsey.
@Spazz and @danoday...thanks again to you both for the compliments. Always glad to help when I can even if it's not always the news we like to hear. lol
That being said, I got to thinking more about these '09 Power Duals last night and as far as fitting on the bike, they will install on the '10 & newer touring models, however, it is the size / location of the Oxygen Sensors that is different. The '09 & older models use 18mm ports near the exhaust ports on the engine while the '10 & newer touring models use 12mm ports near the transfer case to get the air:fuel ratio reading. Because of this, if you were to go with a fuel tuner that required the use of the 18mm O2 ports (ie: ThunderMax) then you could run the '09 Power Duals on your '14 Street Glide BUT if you were to run a fuel tuner that utilized the factory installed 12mm ports near the transfer case, you'd want to go with a set of Power Duals designed for '10 & newer baggers.
Anyway, just some "food for thought" on this fine Wednesday morning!
LT :0)
Call them to make sure
Jimrogers74
