Hello all,
My question is...If I were to upgrade the front fairing speakers & install an amp...Do I have to to have HD "re-flash" the factory stereo? Or do you re-flash only if adding rear speakers as well ?
Thanks for any info,
Chris
Hey Chris
You will have to have it reflashed. Only if you just add the amp. If you add more than 4 speakers you will have to add another amp to push the speakers.
I added a J&M 250watt 2 channel amp and I didn't have to have Harley do anything.
You do need a reflash if you add an amp. I had mine done to show 8 speakers and no amp and it sounds amazing.
Did you get the the stereo flashed without changing anything?
When you say changing anything are you referring to HD radio? I didn't change the radio, just added an amp and speakers.
When you reflash the radio it gives the output from the radio a flat eq curve and also turns on the rear output, so no it won't sound better.
That makes sense. I figured it was too good to be true anyway. I will just buy some more speakers!
when installing any non-Harley amp in your StreetGlide, you want to leave the Harley radio flash Stock, just like it came from the factory ,,,,, if it has already been flashed for the BOOM system, then you need to have your dealer flash it back as """ 4 or 8 speakers, all amps off, enable fader""" from the Harley screen selection menu,,,,,,,
