rear signal conversions?
fongdaddy
5
Curious if there's a kit for the 14 sg were u remove the rear signal lights an all and add the led strips on either side of the fender? I've seen somethings like it but can't find any details.
Thanks
Try looking at custom dynamics website. I think i saw something like that.
Thanks for that site exactly what I was thinking. Has anyone removed the stock rear signals all together and just used one of these systems? Is so post pics thanks
Your going to have 4 visible holes in the fender if you remove the turn/tail light housing.
I knew the hole thing figure I would get a curved plate mount to cover holes just not a huge fan of the rear lights , cleaner the better.
Gonna have to be a pretty big curved plate to cover all 4 holes. Maybe I'm wrong.
I removed my rear tail light assembly not that hard. I used a curved license plate mount and Harley bag lights. street glide 014.jpgstreet glide 016.jpg
twistedsg14- That looks awesome! Its the first time I've seen this treatment, looks like something Harley stylist should have thought of!
I didn't like the stock lights and didn't think they where very bright during the day. the led lights r way brighter, I also have the license plate lights set up to work as rear brake and turn only. I used chrome button head bolts to fill in the stock upper holes. the plate mount covers the rest.
Where did you get that license plate mount? Everything you got going on there needs to happen to my bike (powder coated black).
"twostedsg14" >>>Ok Mann, give it up!!! I need that. I need step by step were to get that set up.
So I found this but looking at the triangle in the middle, it is upside down. Does anyone think there will be a problem with this?
sorry I didn't see the post sooner. but the license plate mount is the kuryakn curved mount j&p parts #383-286. the bag lights are Harley. after you remove your rear light assembly you will see the big grommet that the wires go threw. i used that hole to mount my mount to the fender that way. if needed i can get more in depth about the install just message me. i hope this helps.
I have the charcoal pearl, those bag lights with the smoked lenses and black trim would look sharp...hmmmm
SuperiorGlide
