Rear Speaker problem with J&M proformance AMP... any help would be great.
Airdog72
16
I'm looking to see if anyone has had this problem, I put HD rear saddle bag speakers on my 14 Street glide I also installed a J&M Perf Series 4-CH 360w Amp.
The left rear speaker Blew (tested with OHM Meter) so I got it replaced and installed it, worked fine for a few weeks and now its Blown again. Has anyone had this happen or know what may be causing the problem I don't want to replace the speaker to have it happen again. Harley will not replace it again. The set up is what I have below.
I'm running two 4 ohm in the Fairing and the standard HD saddlebag (2ohm I believe) speakers in the bags. Everything is wired as it is from the factory. The amp is plug and play.
I emailed J&M early last week but haven't heard anything back yet from them.
Thanks for any help y'all can provide
I checked all the cables, it maybe the amp as you stated.. Hmmmmm
Good luck with trying to find the issue.... Call John at J&M and see if he has a diagnostics to check the amp out without blowing another speaker out.
Well I talked to Jim at J&M said to check the gain on that side of the AMP.. Guess I have to find a replacement speaker now.
i find it funny how people here post and post to put other systems down and say how good another is .lol .. but when a problem comes up no one is posting **** you should all be posting here now saying how great it is ..goes to show you .. all these sites are full of bull****ters that push sponser products . but there not here to help when the product ****es up . at least harley stand by there products and replace it . i hope some does the same for this guy.prob had to buy 2 speakers cause ya cant buy 1 im sure..
Hockeyguy26
