removing Light bar on 2015 SG
jolson
want to remove existing light bar on rear of bike to install led but does not seem to be much room back there. The lower fender tip light also seem to be in the way. any ideas? Thanks
Welcome... it's a tedious task... but is very doable with patience.
The way to remove the tail light is with a 1/4" drive ratchet and socket... a wrench doesn't work since the fender is curved. Same thing with the lower running light.... use the 1/4" ratchet and socket.
You can remove the wheel... but that's too much work for just 4 bolts.
Just did it, pretty straight forward if you have a bike jack (I do not) would give you more room. 1/2" socket on a 1/4" drive worked real well.
2015 Street Glide Special
PHXflyer
