Replacing antenna 2015
harleyde63
I am wanting to change stock antenna on mt 2015 street glide special but can't get antenna to unscrew. Any ideas?
Try wearing a pair of rubber gloves on your hands to get a better grip. If that doesn't work then try something like the product in the link below. It should allow you to get a good grip while you unscrew it. The tool should also prevent any damage to the antenna in case you ever want to reuse it. Make sure your tool has the rubber pads on it to allow for the most grip.
https://www.walmart.com/ip/Irwin-Qu...75035&wl11=online&wl12=17238146&wl13=&veh=sem
The rubber is pretty soft, you should be able to just put a set of slip joint pliers on the base and give it a twist. I'd be surprised if any tooth marks don't go away in a day or less.
You can also get smooth jaw pliers. I've got a set of channel locks st work with smooth Jaws for use on plated nuts. Prevents marring the surface.
jdtech17
