Instead of buying a fairing antenna or even an antenna relocation kit I opted to go with the HD Shorty antenna and modify the stock bracket. I will call this repositioning. On the stock mount there is a tab that rides against the vertical support. Just bent the tab a bit to lean the shorty back a few degrees and problem solved. Picture shows stock antenna position vs the installed shorty. Just enough to clear the luggage rack and luggage.
Here's a picture of the mounting bracket bolted up and the tab bent up just a bit to allow for fudging position
