Security siren chirp
Mike.luciano
4
Is there any way to just disable the security siren so it will not chirp? Its so annoying!!!!!! Please help!!!!!!
Sent from my SM-G892A using Tapatalk
You should be able to just unplug it if you don't want the sound anymore. Not sure on your bike but mines under the left side cover.
Not sure if year dependent but this is out of the 2015 Touring Owner's Manual on how to change from silent or chirp mode
Quickly cycling ignition switch ON-OFF-ON-OFF-ON switches the system from one mode to the other.
With the fob present, turn the ignition switch to IGNITION.
When the security lamp turns off, turn the ignition switch to OFF.
When the security lamp turns off (but before the turn signals flash twice), immediately turn the ignition switch to IGNITION.
When the security lamp turns off, immediately turn the ignition switch to OFF.
Seeing as 60% of your posts have been security related, I'm going to ask.
Have you changed the battery in your fob?
Are you having trouble during a) riding b) trailering/transporting/moving c) initial start-up d) all of the above
Do you want the siren alone disabled or the security system. Siren can just be unplugged and removed. Security can be placed in transport mode (prevents start-up but disables motion activated alarm) or disarmed.
Having a hard time tracking down the siren itself lol
Got the lil ****!!! No more chirp
Just can't say enough about buy a bike and before you spend another dime....factory service manual. Just saying.
raharlow
