Selling 23 2014 up full front end set up, Glenndyne,HHI etc
Status
Not open for further replies.
Stick4
sold
Glenndyne 23"
Avon venom tire
HHI raked trees
Metal front fender, denim black.
Progressive lowering springs
Blk rotors
HHI trees have taped caps for air but I have new ones on the way not taped.
I have about 3k in this set up.
$1500 obo takes it. Complete turn key. You will not need anything else.
Sold
Cool setup. You should probably post this in the classifieds section. Good luck with the sale and your new project.
Wow that's a good price.. Pondering if I could refinish wheel chrome and charcoal
21" chrome CM Maverick rim, with matching rear.
Complete Rockford audio system.
Color matched inner fairing
HD tour pak
Lower speaker fairings
10" LA choppers
Bad dad 4 1/2extended saddle bags and fender
V&H power duals
Led lights everywhere
Power commander V
Some motor work
what part of this set up only makes it 14' and up? i have a 13' and would be very interested if it worked or if you want to part it out
I think it's the trees, the forks are a couple mm larger on the 14's
HD tour pak
10" LA choppers
V&H power duals
Power commander V
Some motor work
Is this setup for ABS?
What is the rake Deg?
With the tree's having the taped caps for air but not the AirFX kit correct.
Side note do you having any problem with your air ride losing air over time?
Thanks
HD tour pak
10" LA choppers
V&H power duals
Power commander V
Some motor work
Yes... 49mm forks on the 14/15's make it specific....
Status
jdtech17
