Originally Posted by RuknRole The rider can change the PIN at any time. Refer to Table 1.
Table 1. Changing the PIN
1. Select a 5-digit (1 thru 9) PIN and record on the wallet card from owner's manual.
2. With an assigned fob present, turn the engine stop switch to OFF.
3. Turn the ignition switch to IGN.
4. Cycle the OFF/RUN switch twice: RUN - OFF - RUN - OFF - RUN.
5. Press left turn signal switch two times.
ENTER PIN will scroll through the odometer window.
6. Press right turn signal switch one time and release.
Turn signals will flash three times. Current PIN will appear in odometer. The first digit will be flashing.
7. Enter first digit of new PIN by pressing and releasing the left turn signal switch until the selected digit appears.
8. Press right turn signal switch one time and release.
The new digit will replace the current in odometer window.
9. Enter second digit of selected PIN by pressing and releasing the left turn signal switch until the selected digit is present.
10. Press right turn signal switch one time and release.
11. Enter third digit of the selected PIN by pressing and releasing the left turn signal switch until the selected digit is present.
12. Press right turn switch one time and release.
13. Enter fourth digit of new PIN by pressing and releasing the left turn signal switch until the selected digit is present.
14. Press right turn switch one time and release.
15. Enter fifth digit of the new PIN by pressing and releasing the left turn signal switch until the selected digit is present.
16. Press right turn switch one time and release.
17. Turn the engine stop switch OFF, then turn the ignition switch to OFF.
Pushing the engine stop switch to OFF stores the new PIN in the module.
