Looking for advice. I decided to upgrade to SE 585 cams and this is what I see after removing the cam plate. The shavings are not magnetic. There wasn’t any metal shavings on the oil plug. Oil pump looks fine. Cam tensioner look normal with very minor scuffing.
I do not know where these shavings came from but they must be aluminum and look like they may have been from residual from HD engine production. The shavings are curled and appear like they came from machining the bolt holes.
I talked with the local dealer and he contacted MOCO tech assist. MOCO can’t explain it but didn’t think it was a major issue. The Service Manager said if it were his bike he would replace with a long block. I think this is a rare issue because I can’t find anything on line. Thoughts?
