Streetglide in Bahrain (battery won’t keep charge)
rjruiz1
I have a new battery , and it wont keep charge . I have to recharge it every 2 weeks or so. Any suggestions ?
Could be a sub-par battery... Try a new one. If that one produces the same results, I would start looking at electrical systems to see if anything is drawing excessive current while the bike is powered off.
Sent from my HTC One M9
Are you keeping it on a battery tender when not ridding ? If not, that might be your problem.
Welcome.
First question: How old was the old battery and did it keep a charge or why did you replace it.
Second question: Did you do a drawdown test on the new battery to determine if it is a good battery?
Double check for a loose battery connection. Make sure they are clean and tight.
Parasitic draw is common with multiple electronics.. Any addons and a load test would be a place to start
Sorrycurmudgeon
