thundermax for a 103 street glide
bdcpv
Hi Guys, this week i would install a thundermax ecu on my streetglide.
the engine is the stock 103 with twobrosracing mufflers and twobrosracing filter.
do you think thundermax is a easy and good way to have a proper afr with low exercise temps, best results and accurate idle?
thanks in advance for your time.
I'm running a T-Max on my 107 and it is very easy to use. It idles perfectly and it gives you the ability to make adjustments to the idle, amongst many other things.
I have been running the Thundermax tuner for some time now. It is without a doubt one of the finest tuners out there. You just have to like it more then you do your money. :D
