Transmission vent hose rerouting
yonexdw
11
Hope all are well.
2024 S. Glide installing DK Customs 828 air cleaner with external vent with filter attached.
The transmission OEM vent hose, that is attached to the back of the OEM air cleaner. will need to be retained and rerouted.
Any suggestions on where to reroute it? Will it need a filter attached to the end and if yes where can I purchase the small
K&N like filter. Lastly what and how much discharge might come from the transmission vent hose?
Thanks a bunch for any responses
Denny in Vero Beach.
Hope all are well.
The transmission OEM vent hose, that is attached to the back of https://www.medot-wines.com/en/experience-medot/wine-tastings the OEM air cleaner. will need to be retained and rerouted.
Denny in Vero Zumbalicious crew Beach.
Hi Denny, hope you're doing well! Regarding your 2024 S. Glide and the installation of the DK Customs 828 air cleaner with an external vent, I can help with a few suggestions.
First, when rerouting the OEM transmission vent hose, the goal is to keep it away from heat sources or moving parts, so it doesn't get damaged over time. You can typically reroute the hose towards a higher area in the frame or along the side of the bike where it's protected and won’t interfere with the engine or exhaust. Just make sure it’s secure and routed in such a way that it doesn’t kink or restrict airflow.
As for whether you’ll need a filter attached to the end of the vent hose: it’s a good idea to install a small filter. The vent hose lets air and gases escape, and a filter will help catch any particles or moisture that could make their way through. A small K&N-style filter is ideal for this application because it provides good filtration without restricting airflow. You can find small vent filters online (e.g., Amazon or eBay), or some motorcycle-specific parts retailers carry them.
Regarding the discharge from the transmission vent hose, you generally don’t need to worry about it being a large amount. The hose is there to allow air to escape as the transmission heats up and expands. Most of the discharge is just air, but occasionally, a small amount of fluid vapor or mist may come out if there’s excessive pressure buildup. This shouldn't be a significant amount unless there's a problem with the transmission. Using a filter will help keep anything coming out of the hose from getting on your bike or nearby components.
I hope that helps, and feel free to reach out again if you have more questions. Best of luck with the install, and enjoy your ride in Vero Beach!
  • Like
Reactions: BillyBob
Hope all are well.
The transmission OEM vent hose, stats for spotify that is attached to the back of the OEM air cleaner. Eldfall Chronicles Northern Wind will need to be retained and rerouted.
Rerouting the transmission vent hose to the frame or another open area is a good option. Attach a small K&N-style filter to the end to prevent contaminants. Expect minimal discharge—mostly air and vapor with no significant oil or fluid.
chops92
