Tri bar light hd international models
hogtoni
5
Here is how i did install the tri bar light on my street glide 2014 hdi model.The light is empty here in europe.Take off the empty light from your bike,take off the smoked lens its glued.buy a tri bar light from biker choice part nr 482761 oem#68358-07 take off the smoked lens on the new tri bar light remove the led lights in side the new light and install it to the old light, first you drill a 10mm hole on the left side of the old light for the cables.Order cable from harley davidson part number 69200772 install this under your seat there is tree cables that runs to the tri bar light. Install all back on bike and you are done.If harley dont make a tri bar light make it your self!!!street glide need some extra brake and running light.See harley led light kit 68000111 for instruction where the wires conect.IMG_1155.JPGIMG_1158.JPGIMG_1158.JPGIMG_2145.JPG
K
Here is how i did install the tri bar light on my street glide 2014 hdi model.The light is empty here in europa.Take off the empty light from your bike take off the smoked lens its glued.buy a tri bar light from biker choice part nr 482761 oem#68358-07 take off the smoked lens on the new tri bar light remove the led lights in side the new light and install it to the old light, first you drill a 10mm hole on the left side of the old light for the cables.Order cable from harley davidson part number 69200772 install this under your seat there is tree cables that runs to the tri bar light. Install all back on bike and you are done.If harley dont make a tri bar light make it your self!!!street glide need some extra brake and running light.
Hogtoni,
Apparently you have a good handle on the situation. Like you I have always enjoyed thinking out and building or assembling my own parts from scratch or combining parts to get the ultimate result I desire. Kind of like cooking (which I love), come up with a good dish and everyone wants the recipe. Thanks for sharing.
Low & Slow,
Blues
Where there's a will there's a Harley owner!!! Good job hogtoni.
Hi All,
Another option is, when you can get your hands on Tri-Bar Light Upgrade P/N 67774-10 and remove the circuit board and replace the this with the circuit board of your International type FLHX. solder de black, red and white wire on the on the circuit board (and from the top of my head) the top one is is mass=black and the bottom two Red and white are for running light and brake (you would have to check whcih one is which). Took less then an hour before it worked and it is looking fantastic. I got this tip from one of my fellows in my HDC. Good Luck!
Hi Hogtoni, I am doing the same mod to my bike. I looked at installation instructions for the tourpack led kit as you referd too, it looks like the connector for tail lights located under the seat? I looked at my SGS -15 and I didn´t see the connector there, where did you connect your cable? I also bought Bikers Choice Tri-Bar but they forgot to send wiring diagram for it, do you remeber the colours for ground, running- and brakelight?
Cheers
Hi tko you can see HD pdf instructions led light kit 68000111. Its the number 1 connection under your seat.
Nur Licht oder Licht und Bremslicht?
Here is how i did install the tri bar light on my street glide 2014 hdi model.The light is empty here in europe.Take off the empty light from your bike,take off the smoked lens its glued.buy a tri bar light from biker choice part nr 482761 oem#68358-07 take off the smoked lens on the new tri bar light remove the led lights in side the new light and install it to the old light, first you drill a 10mm hole on the left side of the old light for the cables.Order cable from harley davidson part number 69200772 install this under your seat there is tree cables that runs to the tri bar light. Install all back on bike and you are done.If harley dont make a tri bar light make it your self!!!street glide need some extra brake and running light.See harley led light kit 68000111 for instruction where the wires conect.View attachment 7424View attachment 7425View attachment 7425View attachment 7426
Hallo HOGTONI - Konntest Du so Licht und Bremslicht anschliessen?
Hi Harley-news.ch you must write in english so that i can answer you. I dont know german.
Phatt74
