uses for acessory switch
SapperLDMorgan
53
I was wondering what kind of uses people came up with for the accessory switch that comes on the dash panel of the streetglide,
I used mine to turn on and off the harness for my heated jacket liner, i did not want to run all of the current through the switch so i have the switch triggering a 30 amp relay, and the harness pulling power through the relay, it has worked pretty well so far.
I always wondered what that switch was for...been wondering that for years!
it goes to a harness that is under the seat, right at the base of the tank, it takes a 6 pin deutch connector, (those re-buildable plugs you find all over your bike) but the harness has power, switched power, and ground in it already, i had my powerlet GPS harness on that switch, but wanted the heated gear harness to be able to turn on and off, so i have the GPS harness on the constant wire, and the heated gear harness on the switched wire.
Paul90
