Just upgraded my 2014 103 to the CR570-2 cams. Getting valve train noise. I have the S&S Premium Lifters, also did the Zippers dual piston chain tensioners along with the Axtell oil bypass valve and SE Adjustable push rods set at 3 turns. So it may just be me but I have engine noise...Valve Train and a cam chest rattle at idle, sometimes.
I have re adjusted the push rods 3 times. It just does not sound right to me. It has been in the 40's to 60's here and the oil pressure is at lowest 17, highest 42. I am a retired tech of 45 years and not afraid to ask but it seems or sounds like a oiling issue. I will be taking it apart and looking but I suspect the oil bypass valve....when I installed it I barely had to push on the spring spacer to install the pin. At this point I am thinking if I have to tear it down again to replace the plate and pump also to a upgraded set.
Bike runs fantastic, Really like the cams but the noise is more than stock . I know you get noise from different cam ramp design and I am setting on top of a engine but it just does not seem right.
Any input is appreciated.
