Vance & Hines Power Duals exhaust leak at crosspipe?
rrychner
I recently had V&H Power duals installed on my 2014 SGS. I noticed an exhaust leak where the cross pipe fits into the head pipe. I have loosened everything up on that side and reinserted the pipe to make sure it was in securely. Everything seems good and secure. Curious if others have noticed this, and what solutions people may have done to correct? Thank you in advance for any help.
Yes...
Exact same issue & exact same remedy !
You are not alone...lol
Chris
Same leak here but the more I ride, the less it leaks...don't know if it's all in my head or if the pipes get tighter as more heat is applied or what. I was hesitant at first but after calling vance and Hines, they mentioned that it is normal...whatever that means lol
Hey guys! New to the forum. I know this thread is a year old, but I just installed the Vance and Hines Dresser Duals on my 2013 CVO Ultra. I was looking for help and came across this thread. I too noticed a leak; air coming out at the crossover pipe/header joint. Same here...re-adjusted the pipe at least 3 times. I called V&H yesterday for guidance. The first guy didn't have an answer and put me on hold. I was on hold for so long, the phone re-dialed and gave me a different person. I explained the issue to a second guy and he said he was familiar with the leak. He added that in talking with their top dyno guys, the leak was normal. Like pbadasay said earlier...whatever that means! LOL
I'm thinking it's definitely a design flaw. Unlike your mufflers and stock Harley crossover that slip "ON" to the header, this pipe slips "INTO" the header. You're bound to have a leak with that type of setup. I've thought about either going to Harley and buying their crossover pipe gasket or just add a little dab of Permatex Muffler and Tailpipe sealent to the bottom of the pipe where it's leaking.
Anyway, I'm glad to see it's just not me having the issue. I installed the headers by myself and thought I screwed up!!
Ride safe...
Cajun851 ,
Welcome to the forum ...
Ride safe,
Chris from Long Island NY
Frankcvo
