Will these work on my SGS 14 "plug & play"
Mine too Spazz. I do remember HD had early issues with both fogging and the black version peeling. I looked at a 2015 today and it STILL has the same dual small diameter LED lenses. That is quite odd and for now reason unless they use 2 different vendors.
Yes... they are two TOTALLY different headlamps... and like I said.. the ones you buy from the counter is the ones we have.... FACTORY INSTALLED are the ones with the same size lenses top and bottom...
Odd for sure mine is bigger on the bottom and I took it of my 2010 road king. I wonder if there is any difference in the light beam?
I just talked to my local dealer and they said all the new daymakers have the same size bulb top and bottom, even the ones over the counter they said it is just the new style.
Interesting... that's not what is being sold at my dealership.....
Mine either
Just installed
Either work for me, it doesn't matter as long as it doesn't fog over.
No not yet, not sure which ones to get... part #. Guess I need to call them. Im putting in the upgraded speakers right now, started last night got one in. Will finish this evening. Took me about hour or so to get the one done. Wasn't to bad the three bolts that are tucked back on the bottom was the hardest to get.
I went up to my dealership to order the Fork Wind Deflectors parts guy told me that they might hit the engine guard when you turn sharp but I see some that have them on so I dont know. Anybody got this problem?
As long as you install them correctly, they won't hit. Also they are slottled a bit for slight adjustments.
duckworth
