O ODMC New member Jun 29, 2015 22 0 0 Jun 29, 2015 #1 Was my on way to work and I lost all use of the throttle. Check engine came on and not able to use the throttle. anyone have the same issues here and what was the fix for it
Spazz Administrator Feb 22, 2014 1,856 1 0 Jun 29, 2015 #2 Sounds like you lost the twist grip sensor if it's Throttle By Wire and not cables... if it's cables... check em... Sent from my Note4 using Tapatalk
O ODMC New member Jun 29, 2015 22 0 0 Jun 29, 2015 #3 yeah its throttle by wire. would that trip the check eng light to stay on after starting for about a minute or so?
Spazz Administrator Feb 22, 2014 1,856 1 0 Jun 29, 2015 #4 Yes... TBW will throw codes and alert you like that...Check your DTC'S and post your codes.... Sent from my Note4 using Tapatalk
O ODMC New member Jun 29, 2015 22 0 0 Jul 2, 2015 #5 throttle by wire was jacked up. replaced it under warranty and all good in the hood now.
Spazz Administrator Feb 22, 2014 1,856 1 0 Jul 2, 2015 #6 Good to hear... NOW RIDE!! Sent from my Note4 using Tapatalk
