2014 street glide plug for rear fender
t00lmantim
Does anyone know if there is a plug to fill the hole in the rear fender? It’s under the seat and it’s probably used to route wires for a tour pack, about a 1”X 1” square hole. I just purchased a 2014 street glide from my local dealership and it ended up having ECM issue. Looks like a lot of water from wet roads end up through the hole and ends up in the battery box area. Might pose electrical problems down the road
I just taped over the fender holes under the seat with black Gorilla brand tape. It lasted for years without needing to replace it.
Probably the best fix is the one Hulkss gave you. Never see it unless the seat is off.
I agree with Hulkss: For years, Ive been using 1 inch clear packing tape to keep out moisture and dust. Works like a charm! :cool:
Qman77
