Air Ride Suspension
BigJason
22
I had purchased these shocks from another member late last year and ran them for a limited time on my '16 SGS. Having some unexpected things come up and need to sell the suspension to recoup some $$. All you will need to complete the install is a 3-way toggle switch of your choice, mine is wired internally into the handlebar and is not coming out. The small compressor and dump valve mount behind the right side cover next to the abs module with the 2 bolts and washers provided. I do have extra 1/4" line to add to the system.
$850 shipped in lower 48 states, PayPal is okay to use.
"Elite Series" 4.0 stroke
TAB is proud to announce our latest shocks for the HD-FLH model bikes. The new "Elite Series" shocks feature 4.0 inches of stroke,TAB's latest needle seat cushion rebound control "NSCRC" and all of our new shock mount tops have built in spherical rod ends for longer piston alignment.
Features included;
4.0 inches of total stroke.
New-Needle seat cushion rebound control "NSCRC".
9.6" lowest setting from swing arm to frame when collapsed.
Spherical bearings on both top and bottom mounts to increase longevity.
Complete kit includes onboard compressor and solenoid
3-way switch not included with my setup
Black tops.............$1495.00
Roy Lopez
