Air Wing Rack
Did you use the template that came without Airwing rack, or make your own? I know I was nervous as hell every time I drilled a hole into my expensive tour pack. It all worked out fine though.
Sorry, I don't have a Tour Pack just the 4 point detachable. Seems extremely well made and even though it's only rated for 10 lbs (unlike the King that is rated for 30 lbs) I'm sure I will have no problem using my Nelson Rigg luggage with it.
Oh okay. I think my Air Wing Rack on my tour pack is rated up to 25 lbs, so you should be fine.
Webike Japan
