So after reading countless threads, I decided to pull the trigger and install a RockFord Fosgate PBR300X2, Infinity Kappa 62.11i speakers, and a Biketronics BT335 Line Leveler on my 2015 Street Glide Special with 6.5 and stock flash. System sounds like trash. Messed with the settings on the BT LL a little but put them back to stock since the every forum I have read continues to harp on the stock setting from Biketronics is supposed to be spot on.
Setting on PBR300X2 - Gain 6, Filter (AP),
Setting on BT LL - Stock settings.
HU Settings: Treble at Center, Bass at Center.
Auto Volume: Off
I have checked power, ground, and speaker connections. Everything is square in those regards. Help!!!!!!!!!!!!
Auto Volume: Off
