hi morning guys have a massive problem with my street glide st swapped the bars over to 12 la choppers one the wire pulled pretty easily but now i have no functions on left clutch side at the switch have checked continuity of wire and also voltage at can bus pins at connector all are fine but when plugged in nothing .if you swap plugs over A TO B then everything work but then nothing or right hand side works .Have checked fuses and switch works fine when swapped to other plug .have voltage at pins continuity of wires am i missing something as im now scratching my head as to why it dosent work
