OK, here is what is going on. I recently replaced my main shaft seal due to oil leaving my crank case and ending up in my primary. I replaced the shaft that the seal sits on as well.
Everything worked perfectly for about 2000 miles. Then I noticed that my oil level was at the half way point on my dip stick. Today after another 500 miles (so 2500 since seal replacement) I checked the oil and it is 3/4 down from full on the dipstick.
My bike is not leaking oil. I do not smell oil in the exhaust.
Tomorrow I am going to pull the derby cover and try to determine if there is an excess of oil in my primary drive case.
If the oil is going to my primary drive case (again), I have obviously screwed someting up with the seal replacement. But what?! I bought (and used) the Jims tool to remove the old seal and seat the new seal. I really thought it went well. I made sure to put assembly lube on the new seal and the new shaft it sits on.
What could I have done wrong? Are there any tips and or tricks that could help if I have to go through this again? Could the oil be coming from somewhere else? I could have sworn that the only place engine oil can get into the primary is through the main seal.
Please help.
Ride safe.
Thanks.
Please help.
Ride safe.
Thanks.
