Docking point bushings 2015 Streetglide
gvette95
8
Anybody have a source for the plastic C shaped bushings that are on front of tour pack quick detach bracket,I have 1 side that keeps breaking.Is there anything else out there that works better than the stock ones? Thanks in advance
Have seen 1 after market set but can't remember where. I just replaced the one's on my tour pak with stock. If your breaking them you may need to look at mount your using.
Something may be out of line. I've never had one break in the past 11 years.
Make sure the mounting points (4 of them on the bike) are positioned correctly. If I remember right, they have a raised horizontal line on the rubber that should be facing up. Sometimes over time they tend to rotate, making it harder to mount and un-mount the Tour Pack and possibly causing the "C" bushings to fail. If the raised horizontal line of the rubber is facing up, you'll find it easier to mount and un-mount the Tour Pack. Might be worth a try.
Denaliman855
