Just took delivery 2017 SG CVO interested in Vance & Hines Power Duals with Hi-Output full exhaust system. I understand I will get pushback on this but I want to use the FP3 tuner. I have used Thundermax systems in the past and I know other systems are preferable to the FP3 however, my question is: since V&H does not have and will not have a map for the 114 has anyone used this exact setup and used the existing map (Stock - Plus) and had 2 - 3 hours of autotune? If so, has your resuts been satisfactory? What if any changes would you suggest?
Thank you in advance!
