FP3 Update, NICE!!!
Well, no luck. Not sure why it's not working, can't find it anywhere on the version I downloaded this morning. At first I thought maybe I forgot to sync my phone, did it again and still no luck. Went for a quick ride thinking maybe you have to be moving, no luck again. So now it's raining so I'll have to keep playing with it, can't seem to find any other info except on another forum, but that doesn't tell me anything either. According to one of the V&H guys on another forum it works off your phone, so it shouldn't be necessary to have the 6.5 radio. No info about this feature on the V&H web site either.
If anyone has any luck let us know.
Found it under the map that is loaded on the bike under General.
I've been through it 3 times now, doesn't show up on mine, strange. I'll keep trying.
EDIT: OK, after trying 4 times to sync my phone and not being able to see it, I deleted the app off my phone and reinstalled it. Presto! Once it drys out here I'll take a run and see how it goes. Says it will calibrate once you reach 60mph, then you'll be able to accept it and reflash.
I found it, had to go to my app and force it to update.
Here's some additional info I found for anyone having issues on an iPhone getting this to work.
If the app doesn't show the Speedo Calibration, delete the app from your phone and re-install it, then sync your phone again.
If you run the Speedo Calibration and it only shows the Reported speed but is showing 00.0 for the Actual speed, go to Settings>Privacy>Location Services>Fuelpak FP3 and make sure you check either "While using the app" or "Always" so that the app is able to access the phones GPS feature.
make sure you connect to the FP3 and update the firmware of the FP3 itself... not just the app....
Even after the firmware update, it doesn't seem to work. Sadness. I did it 2 times and each time it still says speedo is off by 4.3%. Maybe this isn't ready for prime time yet. Got all excited for nothing...
Give them a call tomorrow....patience. I still gotta get a tuner for my RGS and FP3 won't work for my 120.. I called 3 times and 3 different people.. so lookin at about a grand for tuner and dyno since nobody can't give a word of confidence for a good tune for PC or PV... I could go Thundermax.. but it's a grand by itself
Sent from Note4
Same thing here, just got back from giving it a couple tries, says I'm 3.3% off each time. No biggie it's not like I ride around as fast as all the crazed soccer moms anyway, I'll wait for them to figure it out.
I was able to calibrate mine today. Mine was 4% off
But if you do it again will it now show the correct speed or will it still say the speedo is off. I guess we were expecting if the process is done a 2nd time, it will basically show it is not needed.
I will check it again in the morning on the way to work and I'll let you know.
You are correct, I checked it again this morning on my way to work and it still said it was 4.5% off. Let me know if you get in touch with V&H. Thanks
Did you flash it after it calibrated? Just wondering if it works the same as making a throttle adjustment.... those must be flashed to take affect
Sent from Note4
Yeah, I flashed it once I stopped the bike. Pulled over on the side of the road and done it. I'm gonna try it again on the way home and see if it works.
More than likely it's the operator, you know me Spazz!
