I have a 2014 SG with almost 50k miles on it. For the second time, I’m noticing it’s leaking oil. The first time, pulled the cover off, re-torqued the bolts, and that seemed to fix the problem. Looked at it today, and sure enough, the same thing, albeit from the air cleaner side, in the front. Question, how long can you reuse the seals, I know they’re metal, wondering if I should replace it. Also second pic is of the air cleaner “casing?” Im sure there shouldn’t be caked up oil there? Thanks as always!
