Help??!!
flhxgirl
I have 2010 flhx with 82k miles. RUNS GREAT!! just did 103 upgrade with 255 cam & high pressure oil pump. bout 2000 miles on rebuild. Last couple days it runs great & all the sudden check engine light comes on & power cuts out!! If i twist throttle all the way rpms only raise 300 (yes hundred). I shut it off for a few minutes ig fires up & runs great again for a few minutes. If anyone has had this happen i'd love to know how to fix it. Staying close to home or switching scooters sux!! I luv my flhx.
Welcome to the forum and not sure what this could be. Almost sounds like the ECM or the cam sensor. Not sure who if you did the work or a shop but I would take it to one. Hey Spazz looks like another close rider that's 4 or 5 of us in the area we should ride sometime soon like maybe at street vibrations?
If it's throwing a code, cross reference it. I agree with Crank senso or ECM issue though.
Another often overlooked item is a fuel injector malfunctioning when temps change.
...Hey Spazz looks like another close rider that's 4 or 5 of us in the area we should ride sometime soon like maybe at street vibrations?
Maybe! Welcome from Reno, NV... looks like you got a few good starting points on your issue... I wish I could add to the possible solution.
If you don't want to bring it to HD... There is a VERY knowledgeable guy that I trust in Reno.... Johnny at the Chop Shop. I am going down there today... I will hit him up with your problem and see what he says...
Johnny wasnt in the shop sat... I will check with him on Monday...
Welcome from Alberta Canada. Where you able to see someone and get your issue fixed. Hope you did.
Scottall50States
