Installed heated grips
CA Bowhunter
22
Not to bad to install had to remove the right side cove , tank,seat and the outer fairing then tilted the inner fairing forward. All together about 2.5 hours and warm hands riding to work tomorrow. Life is good.
Randy
I went a different route last night. I went online and ordered a set of First Gear brand heated gloves with required accessories from J&P Cycles. Ended up spending $244. I did get the dual controller so I will probably end up getting the heated vest down the road.
Can you post a parts list and when installed a review???
https://www.jpcycles.com/product/383-459 - Y-Harness for heated gloves
https://www.jpcycles.com/product/382-136 - Dual Heat Controller
https://www.jpcycles.com/product/114-532 - Large Men's Warm Gloves
https://www.jpcycles.com/product/122-903 - 6" SAE connection to DC Coax
Total cost $262.95. The fourth item is for me to hook up to the battery tender instead of having an additional wire that is hooked straight to the battery. I will let you know what I think of them once I try them out a couple of times. Wish I had them tomorrow for a ride I have planned but too late for that.
Be sure to install a bigger fuse in the factory charger cable. Hopefully one comes with your kit.
24SGLIDE
